SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Feb 10, 2004 5:41 pm
I have only accessed this section of my engine with it out of the car. If you want to get to these parts with the engine in the car you have to do the following basically:1) Jack up the car2) Suspend the engine3)Remove the engine crossmember/engine mounts (along with everything else that its attached to (steering rack, etc)4) Remove oil pans5) Now you can access the internal parts of the engine
So basically, by the time you finish this monumental task you will have wished you would have just taken the engine out of the car. The short block internals can only be accessed from the bottom of the engine, and the oil pans need to be removed. But if you can clear the engine crossmember then you will still find it cramped to get the crank, main bearing beam, etc out.
Bottom line, much wiser IMO to take the engine out of the car.
