Replacing rear suspension bushings
Lubrecon
Car: 2005 and 1997 Q45
It's me again. Although I have decided to not do anything about the slight out of camber spec on the right rear side of my 2005 Q, I can't stop thinking about how replacing the bushings would change things....maybe even bring the right rear back into spec where camber is concerned.
I was told bushing replacement is a difficult job and requires removal of all parts, so the bushings can be pressed out or otherwise removed.
Has anyone had any experience with replacing the rear suspension bushings? It looks like two, one on the front link, or lateral arm and one on the radius rod would be what I need to replace. However, the one for the lateral arm is in the wheel housing, or the axle as it is identified in the FSM.
Thanks for any help or suggestions.
LoxMurda
Car: 93 Infiniti Q45 212k R.I.P.
94 Infiniti Q45 180k and climbing
what model are referring to?
Lubrecon
