Replacing rear shocks
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Infinit35
Car: 2005 G35X Sedan (Auto)
Can someone tell me how to remove the bottom bolt on the rear shocks? Got the nut off, but the bolt just keeps turning and not come out. I'd appreciate it if someone could send me the section of the repair manual on replacing the rear shocks. Thank you inadvance. :biggrin:
telcoman
Do a search for it.
Its here
fsm-list-for-your-g-t525067.html
Telcoman
audtatious
Once you get the nut off the bolt use a rubber mallet to knock it out. Should come out relatively easy if you have no load on it.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
