CRyan »
https://forums.nicoclub.com/cryan-u23575.html
Sun Dec 09, 2007 6:21 pm
WELL, I think I've done something not so smart - I need your guys input on this. (CLIFF NOTES AT BOTTOM OF POST!!)
So, as most know I've been doin5g some work on my car while it is in the shop getting a rack and pinion. I've ordered a set of wheels (18" 7.5" wide with a 35mm offset on all four) and I've ordered a suspension set up (KYB AGX's with a german made spring. . .1.4" drop all the way around. . .)
Before I get to the big question - please someone reassure me that these wheels will clear the fenderwell with that kind of drop. . .Anyway.
So in all my cars, I've grown fond of running royal purple 15w40, and I decided to change out my oil. But theres one difference. Seeing as right now I will not have the time to replace the rear main seal, I added a "rear main seal repair oil" which took place of one quart of the royal purple.
Someone please tell me my car won't blow up when I crank it, or that it isn't bad for the car. And if this stuff somewhat works.
The seal isn't leaking TERRIBLY bad, but its noticeable. . .I dunno, I'm regretting now if I should have used that additive.
Cliff Notes -1. New wheels (18" 7.5" wide with 35mm offset) Will they fit with a 1.4in drop all the way around?2. Changed oil - used royal purple - substituted one quart with rear main seal repair - will this help or hurt the car?
Thanks guys - I'm just really nervous and in need of some kind of guidance/advice.
ThanksCRyan.
