180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Dec 09, 2005 5:07 pm
piston comes out by unscrewing it out. When the piston's out, you'll see a bunch of snap rings behind it. You'll want a good set of snap ring pliers for it, trust me.
When reassembling the calipers, lube the sides of the piston with brake fluid and the inside of the boot with the grease that's supplied with the seal kit. Make sure the rubber ring on the inside of the piston (a little bit deeper than the boot) is also lubed up with brake fluid. Otherwise you can spend an hour scratching your head wondering why the piston isn't going in. Ha ha ha. I said "it isn't going in" ha ha ha
