Replacing radiator hoses - what else while I'm in there?
emm3seven
Car: 2011 Infiniti M37x w/Tech + Touring
My 2011 M37x has a paltry ~84k on it, but the top radiator hose is starting to leak a little on the engine side, so I'm gonna replace the coolant hoses once things warm up a little here in the US Midwest.
Anything else that a low-ish mileage, 14-year-old VQ37VHR should need while I'm already prepping for some spring maintenance? Timing chains/guides? Galley gaskets? Water pump? Thermostat?
TIA
Ilya
I'd include things like air/cabin filters and PCV valve. Check your engine belt and fuel lines as well.
Yoda's Master
Car: 2012 M56
2009 370z
the plastic heater hose connector behind the engine and the plastic bleeder on the driver side
emm3seven
Thanks for the suggestions - what’s the story with those plastic coolant parts? Do they get brittle and crack/leak with age?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
emm3seven wrote:
Wed Mar 05, 2025 2:34 pm
Yep. Some models get it worse than others, but all that plastic eventually dies.
