xscorex »
https://forums.nicoclub.com/xscorex-u148544.html
Tue Jan 26, 2010 4:27 am
Ok, since no one wanted to chime in, I went ahead and did this myself. I have no idea if this is the correct way, or if it is even safe. But this is how I did it. This is for a 95 pathfinder rear quarter window.
1. pull off the plastic vent piece off the back. Its just for looks and serves no function. it is held on by 3 pop rivets, just slide a tool under it close to where the pop rivets are and pop it out.
2. pull the old glass out. This was incredibly hard. i had a heat gun and a scraper. It still took forever to get it all off. Then i took a can of paint stripper and took it all the way down to the metal. You might not want to try this if you have a nice car in case you get some on the paint. Mine is a junker so i didnt care. Once it was good and clean I taped offthe pinch weld where the window sits and sprayed a little bit of primer back on the bare metal I just cleaned.
3. I went to autozone and got a roll of butyl tape. This stuff looks like a long roll of black smooshystuff. Dont touch it with your fingers. You dont want the oils to get on it. roll it around the pinch weld.
4. If your window is totally clean and free of any oil & what not, then stick it on the butyl tape.press down good & hard & get it in place.
5. I did not see any clamps or any other way to keep the window in place. It seemed as if the window was held in place using only the adhesive. On the stock window this seemed to be more than enough since it took forever to get the old broken window out. after the window is in place with the butyl tape, I ran a bead of 3m urethane adhesive around the window to seal it all up good, while it was still wet i pressed the gasket seal that i took off the old window back into place. basically this just gives it a finsihed look.
6. I let it dry for 2 days in my garage.
Finished! The urethane caulk tube cost about $13 from NAPA and the butyl tape was $9 from autozone. Took me about 3 hours to do. most of that time was cleaning & scraping the old window out & making sure my replacement window was clean as it was taken from a junkyard.
