there were 14mm bolts to take off the caliper cover so that i could replace the brakes, but to get off the entire caliper i think the bolts i need to remove are bigger. i'm not very mechanically inclined, so i hope i'm trying to take off the right bolts here.
i followed the diy guide
http://www.nicoclub.com/archives/altima ... otors.html
one of the pictures shows the rear caliper assembly, in my pic below, the bolt on the left is the 14mm bolt with another one below to change out the pads. the bolts i'm trying to remove are the larger ones on the right, which i'm pretty sure are the bolts holding the caliper on. those things are holding on for dear life!
my problem with putting a pipe over the wrench is that i don't have the space in the wheel well for a bar. and the caliper is in the way of placing the wrench so that it's not in the wheel well.
