replacing OEM H4 headlight bulbs w/ LED H4 bulb
wildpig
Car: 2003 BMW M3 Convertible
2004 Infiniti G35 Coupe
2002 Pathfinder SE 4x2
So i was trying to do that but after pluggin in the connector to the back of the LED bulb, it doesnt light up. when i test connect both the LED bulb and the OEM bulb directly to battery terminals, they both light up. so the new LED bulb i got is good. but why does it not light up connecting to the car connector?
I notice that the OEM bulb is higher wattage and current than that needed by the LED bulb so it doesnt seem to be lack of power supplied by the connector. I did try to reverse plug the connector into the LED bulb but still no luck..
Anyone with any suggestion? I got an 02 pathfinder
fueler
Car: 2 Nissan's
2 BMW's
LED headlights???
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
-face palm- dont do that........
wildpig
ya, LED H4 bulbs. White color so hopefully will be enough to make up for the fact that they are dimmer than the OEM halogen bulb. They are much cooler and more energy efficient. You can hold one in your hand while it's on without any discomfort.
I just want to test them out to see if they are bright enough to replace the OEM halogen bulbs. Was considering the Xenon HID route but want to try this route first. I know LED is nowhere as bright as xenon HID but i just want to see how they are against the OEM bulbs. No luck so far ;(. much appreciated any suggestion. Don't know if i am missing anything... ;(. Might have to go the Xenon HID way.....
This is what i got btw anyone else is interested: http://www.meritline.com/h4-102-smd-fog ... rce=fghdac
I got mine from ebay for cheaper price but same 102 SMD H4 LED bulb... If anyone else have experimented with LED bulbs, much appreciated your thought too.
wildpig
so anyone has any input into replacing the OEM halogen bulbs with LED bulbs? Not sure why the LED bulb doesn't turn on. much appreciated any suggestion before i abandon this to go the xenon HID way. Thanks
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
wildpig wrote:so anyone has any input into replacing the OEM halogen bulbs with LED bulbs? Not sure why the LED bulb doesn't turn on. much appreciated any suggestion before i abandon this to go the xenon HID way. Thanks
You've been face palmed by our resident ricer Innovazn, that's bad. Keep your lights stock, end of story.
wildpig
heh guess i ll just hv to go xenon hid way. oh well, failed experiment for LED headlight....
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
Color is nice on the LED bulbs, but quality generally sucks and light output just isn't there.
HID is probably what you should go for, but then again don't discount the stock H4 headlight bulbs, they aren't so bad =p
wildpig
ya, LED bulbs definitely not bright enough. wont even light up when I connect.. will probably get hid light...
somgaet
Car: 95 240SX SE
I know this is an old thread, but LEDs aren't like regular light bulbs. Positive has to go to positive and negative has to go to negative. If you accidentally swap them around, they will not work like on a traditional light bulb. That being said, I think you have to swap wires in the OEM plug for this to be true and for your LED bulb to light up. ... If not, then I am obviously wrong. Anyhow, check that 12v is on the 12v side of your LED bulb and Ground is on the ground side of the bulb.
wildpig
I gave up on LED headlights. HID will be the way to go for now. LED just not bright enough right now.
