z.Leinbach wrote:well, this morning at -9F trying to start the ol lady,the neg battery lead started to smoke a little and the wire casing had split, sooo question is, how much of a PTA is it to replace the leads to where they need to go. also i will be in the spring or summer maybe replace the engine harness and trans harness, so i can have my reverse lights back. along with the phase 2 injectors.
on another note ill also be replacing the clutch and rear main seal and other bits to the clutch. soo i have a NA, would consider honing out the bell to fit a tt flywheel and clutch, but is it worth it? i drive spirited and will be daily driving it still. so what clutch and flywheel package would be best, also will be upgrading the clutch fork and a solid shifter brace, and short throw. topped off by fresh headers, and maybe a cat delete. and new straight or x pipe. at 2.5" need all opinions other then sell it or pack it. lol
What are your future plans for the engine? TT swap? nitrous the NA?
If not, no point on using a TT clutch and flywheel. Way over kill IMHO, the addition of rotational mass and costs.
Just got with a upgraded NA size clutch and fly.
The upgraded clutch fork is a great.
