Did the readings that I gave I think 3 posts back help any? As I mentioned, neither one of them would alternate, they both maintained a certain voltage at a given rpm. Does it sound like I have bad o2 sensors or does it sound like something deeper?Q45tech wrote:Measuring the [peak or minimum] voltage with a VOM tells you little, what counts are the shape of O2 waveforms [with 0.5 volts as centerline] and the number of cycles [lean -rich-lean] per minute.
The ecu understands anything over 0.55 as rich and anything under 0.45 as lean.
http://autolabscopediagnostics.com/sensors2.html
Look at before [old O2] and after new O2 waveforms.
The engine temperature was at around 193 degrees when the most recent readings were taken with the new sensor installed on the driver side and the old sensor still in on the passenger side. The readings from both sensors were steady at 2000rpm. The only difference now is that the left sensor which is the new one is giving me a reading of 0.930v. Slightly higher then the old sensor and the right sensor is giving me a reading of 0.320v. Other then that, they both stay steady at 2000rpm. Now they do change slightly as I increase or decrease rpm. When I stomp on the throttle, they both jump up to around the same .930 and drop off to .001 or .000 when I let off the throttle but when maintaining any certain speed, neither fluctuate between low and high. For example, If I followed what Paul Wall said, then the left sensor would stay reading .930v and the right sensor would continue to read .320v for the entire 10 seconds at 2000rpm. There must be a problem deeper then the o2 sensors if the new sensor is apparently reacting the same way as the original sensor was on the driver side.Q45tech wrote:You must heat up O2 for ~ 5-10 minutes to simulate a steady highway speed [2000 = 60 mph].
The heaters get weak and the sensor gets sluggish, eventually [30 minutes] almost every O2 will switch.
What new O2 do is greatly speed up the time to first switch so the mpg economy gets better faster.
The ecu is baised to hold a dead sensor at 0.4-0.6 so ecu is preprogrammed to produce 14-16 A/F regardless [without switching].
To get the finest best emission HC and CO the system must be zeroed in on 14.7 A/F because the cats are metallurically optimized for that.
Now E10 changes all that the 3.3% extra O2 in fuel FOOLS O2 sensor and ecu to enrichen the injection pulse by 3.3% MINIMUM so engine uses more fuel.........but that factor alone is only ~~~ 0.5 MPG.
Hopefully everyone learns how the adaptive learn works to zero in on the minimum injector pulse at a steady rpm/speed that will achieve the highest probability of ~~14.7 A/F.
But the O2 sees 4 cylinders so it is an average of all 4 since the fuel trim is a bank of 4.
For self protection the system cannot lean things to much [melt pistons/valves from extra heat] so +- 20% is rarely achieved even with a single dead coil or injector.............2 coils or 2 injectors in the same bank can be a real problem if one keeps driving.
The needles don't stick, they just don't jump from high to low voltage like for example 5 times high and low within 10 seconds. The readings will gradually climb with the rpm. The left sensor reads higher then the right. But other than that, neither of them fluctuate high and low. When I let off the throttle rapidly after holding it at 3000rpm, the sensor readings will drop to .001v for the left and .000v for the right and climb back up to .930v for the left sensor and .750-.830v for the right sensor. And when I stomp on the throttle, the left sensor reading will fall to .200 and then climb to.930v. The right sensor will drop to.001 for a second and then climb to .780v Once I reach 3000rpm. As soon as the rpm levels off at any given rpm, the left sensor will read around .900-.980v and the right sensor will read around .300-.340v.Q45tech wrote:Try swaping in your spare ecu to see if any changes in O2 [the one that appears stuck].
Hey Matt- I hadn't used my Nissan Data Scan for a while so I plugged it in and made a few runs this morning. The scale is 0-100. Both sensors reacted the same. I'm not sure if it's voltage or % but here goes:mattd1979 wrote:Can anybody that has a consult clone, like obdscantech or ecutalk, connect to it when you have the time and see how the readout is on the sensors. Are they switching ON and OFF or High and Low volts or are they maintaining a certain voltage at a given rpm? I have a new sensor installed on the driver side as I said earlier in this thread..........
