Replaced new fuel pump and filter after pump started humming loudly about a month ago. Car ran fine for a couple of weeks and then stopped again. Took the FPCU out and the noticed the solder on the IC board where the NEC K591 contacts were charred, not bad though. Also, one of the K591 transistors had signs of melting and ash around it on the FPCU body. Has anyone replaced these on the IC board with success? The pump is good which I checked by grounding the lower left contact on the FPCU connector to the bolt which holds the FPCU unit.
How risky is it to drive the car with the fuel pump grounded this way and operating at full capacity until I get the transistors to repair the unit? Previous older posts on this topic, especially the very informative post by tangalora on 10-12-2003 were extremely helpful when I replaced the pump on my Q. That post states:
"Note: I drove the car for more than a week (about 200 miles) with thisalligator clip shorting the fuel pump to ground bypassing the three-position (
[email protected] to 5.7 volts,
[email protected] to 8.1 volts, & fast@11 to 14 volts battery voltage) fuel pump control unit settings. Note: Online mechanics estimate the old fuel pump might last a few weeks(running full speed as it is when jumpered to ground); while a newfuel pump may last a few months in this temporary full-power state. Note: It is recommended the fuel tank be kept full whenever operating the Infiniti Q45 in this state as the fuel pump is cooled by the gasoline in the fuel tank. "
Can anyone confirm this? I don't want to risk having to buy another fuel pump, but at the same time need to have the car for short distance local runs until I can locate the parts to have the FPCU fixed.
BTW, does anyone have a used FPCU for sale, or a source for the NEC K591 transistors?
Thanks much!
