Bodge420 wrote:i need to replace the back glass in my 1992 Q and am wondering the the back glass from all Q's from1990-1993 are interchangeable.ie if I bought used back glass from a 1991 could I put It on my Q??also if anyone knows of a place that understands actice suspension maintenance in the new england area i would love to know where it is located?
Installing windshields and backlights is a specialty. Doing it correctly so that it doesn't crack or leak is tricky. So is removing it from the donor vehicle without damaging it. I work for an auto glass company, and we usually don't bother trying to save existing glass, as removing it safely is too difficult and time consuming, not cost eff4ective at all.
Check with a REPUTABLE auto glass outfit in your area for a quote on labor only to remove donor glass and replace existing one with it. Don't forget the trim kts that are frequently needed. My '05 F50 glass company COST on windshield is $130 each X 2.
If you insist on doing it yourself, be prepared to damage the glass or the car, and to have wind/water leaks. I'm not saying it can't be done, but it requires much care and time, plus more cost than just the glass itself.
