ascari wrote:I just bought a second hand M45 S. We have bumpy roads in my city and its kinda stiff...
When I read about the spare parts i found out that M45 S comes with a different suspension that the regular M45 ...
So i'm thinking about changing the suspension to the regular ones (i dont care much about the performance) ... my question is, will it make a difference ? .. will it make the car more comfortable ? .... also, do you think it might cause me any problem ?
thankss
If it is similar to the 2007, both the springs and the shocks are stiffer.
As far as OEM "non sport" springs or shocks, incredibly expensive to say the least.
The aftermarket alternative "non sport" KYB's, won't change a whole heck of a lot in terms of ride quality.
So, your best bet are tires (the cheapest route). Switch to a good touring tire since performance is not a priority. That will make the most difference-afterall they are the only things that touch the ground (hopefully).
Other than that, going down to a 18 inch wheel will help out as well especially combined with a touring tire.
In the mean time insure your cold tire pressure is 32 PSI.
