TXCumtrensh »
https://forums.nicoclub.com/txcumtrensh-u30572.html
Mon Feb 12, 2007 3:26 pm
There is a Tamperproof torx screw, that holds the back of the cover on
you have to remove the battery, or the entire airbox assembly to replace the headlight bulb (depending which headlight needs replacing)
you remove the Torx screw, then unscrew the weatherproof cover (unscrews)
there is a big 1" plug that is now visible, turn that 90 degrees counter clockwise, and the plug will come off.. there is the HID bulb, unclamp the hold down, and remove the bulb
while installing new bulb, make sure you dont touch the glass, and then just reverse the steps
you should be all set
