i have blue leds in my footwells, and it's a different blue. more of a aqua kinda blue. where as the interior lights are blueCoupeVQ35CVT wrote:After looking at pictures and LEDS in person I believe most LEDS in the common "cool white "blue" red" "amber" "green" shades are all the same colors.
that's normal. i just leave mine in the OFF position until i actually need them on.BzOaY wrote:The problem i have had with my LED swap for doors and map lights is that they still glow even after all doors are closed and everything it only does it at night, and its not that i cant see it during the day it is cause my lights are on at night and it somehow gives the map and door lights power and emits a little blue lite in all of them... idk how to fix it or if it is normal
I have all V-LED dome lights and V-LED strips. I put superfluxes(oznium) in my cubby hole and air vents and I can definitely see the difference. Now in my case, it really didnt matter because they were separate areas and the colors glow blended a little but in your case with the way our domes are i think it would pretty much be like two paint swatches side by side so it would be easy to tell if they were off a little.srwong wrote:i'm afraid if i get 1 bulb from a diff site it'll be a diff blue. that's why i thought about replacing all 3.
so should i just replace the one that went out with the same one?
yea that's what i was thinking would happenR. wrote:but in your case with the way our domes are i think it would pretty much be like two paint swatches side by side so it would be easy to tell if they were off a little.
Just my thoughts...
yea, my footwells already dont match my interior lights. but theyre far enough apart that it's ok.DiamondWVU wrote:ohhhh I didn't know you were worrying about color.
yea, i'm probably gonna do that.Blackmobile wrote:just replace them all, bulbs are cheap(ish).
