joecz »
https://forums.nicoclub.com/joecz-u73523.html
Thu Aug 30, 2007 10:39 am
I removed the gas cap before pulling the pump fuse. And, I cranked it a good number of times after it died. So, imagine my surprise when the engine went "thunk" instead of starting!
By the way, for those trying this at home, here's some details of my experience..... besides the injector, you need 2 new o-rings and a new rubber bumper that presses down on the injector inside the cap that holds the injector in place. Two screws hold that cap in place, one was easy to remove, the other refused to give in for the longest time and the Phillips slot in it was destroyed in the process (bad design to not have used bolts here). To get the injector out, I grabbed onto the flat sides tightly with a large visegrip (there is just enough room for it at injector #8) and slowly rocked, pried and pulled. It came loose suddenly and as it came up, the plastic tip surrounding the end of the injector (now brittle with age) impacted the edge of the opening and broke into several pieces. Luckly for me none of the broken pieces fell down into the cavity. So, be careful. Clean out the cavity before installing the new injector. There wasn't a lot of crud, it was very clean - much cleaner than I expected - but there was some residue from the old o-rings that was worth removing. Lube the new o-rings with Vaseline and the new injector slides into place with force. I used the cap to get it in the last 1/8 inch. Not recommended, I know, but it worked out fine and got it fully in place.
This was not hard at all; if it wasn't for the gas that leaked in and the time consuming project to get it out, I would catagorize it as an easy repair. Saved me over $600 by searching and asking my questions here.
