Replacing HS Header with OEM
StreetDreamin
Car: 90 240sx
I have a 1990 240sx (sohc KA24e). Currently I have a HotShot header on it, but it's too loud so I ordered an oem exhaust manifold from midway parts. But looking at the oem part and the HS header, the oem manifold will not reach to the cat converter. Did I order the wrong part or are there more parts necessary? Thanks in advance.
NISTECH
it may matter weather your car is califonia emissions or federal emissions, I know this plays a part on some of the nissan products, Do you have any pictures of your exhuast and your new parts?
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
My buddy had the same problem with the exhaust being too loud. There is a simple 20 dollar fix. We went to meijer and bought a cherry bomb muffler even though it looks more like a resingnator. We welded it in abought a foot after the catalytic converter. It cut the exhaust noise level in half.
StreetDreamin
Car: 90 240sx
I'll try to get some pix up in the next day or so. I don't have a garage and its been sprinkling over here.
StreetDreamin
Car: 90 240sx
I think i need a lower exhaust manifold?? I dont even know if thats a real part. But I got some pics of my situation. Hope it helps.My new oem e manifold:
Here's a zoomed out pic of my header:
Here's one zoomed in:
NISTECH
well it looks like you original exhuast has been cut off and a new flange has been added where the header attaches to the exhust pipe. Snap a shot uner the car where the header bolts up. I am betting a large chunk of your exhuast has been cut off.
The manifold is the correct one though.
StreetDreamin
Car: 90 240sx
What is a nem flange? Sorry, I don't have access to a lift. The exhaust flow is from the hotshot header, then into a high-flow cat and 2.5 in brm exhaust provided by Greg. So what does this mean in terms of if i want to go back and use the stock manifold?
NISTECH
*new*
It sounds as if the header pipe[pipe between factory manifold and cat] has been removed, that is at least what else you'll need to put the exhaust manifold back on.
StreetDreamin
Car: 90 240sx
Thanks. I was confused (n00bness) and thought a header was the exact same thing as the exhaust manifold. So I guess I need the header and the gaskets that connect it to the e manifold and cat? What else can there be? I have these diagrams from Dan Tech, but not sure if i need any of those other smaller pieces. Do i just need the 20010 piece? Thanks for all your help man.
NISTECH
every thing in the red circle is what you'll need, unless you have an automatic transmission then you'll need everything in the box at the upper left
StreetDreamin
Car: 90 240sx
I have a manual. What is a nem flange? and can you name all those parts for knowledge sake? Thanks soooo much NISTECH!
NISTECH
20010= header pipe.20511=upper header pipe heat shield20510=lower header pipe heat shield20511m=header flenge shield20712=header to cat gasket20671=upper and lower heat shield clamp.the part numbered ones like 08915-5381a are the actual factory part numbers and are all bolts to attach the sheilds.
"new flange" not "nem flange" sorry.
