Replacing Hood Struts on 97
lpreston
Car: 97 Q45
I used the Tuff Support brand, part number 612935. These instructions are based off this part. A cross referenced brand may vary slightly.
The ball mounts on the stock part are permantly attached to the strut. Your replacements will require replacement ball mounts. The Tuff Supports included them.
Tools required: 12mm open end wrench. 13mm wrench.
You are going to need an assistant or something to prop the hood up while you are replacing the struts.
1. Remove the bottom strut mount by using your open ended 12mm wrench on the nut directly next to the strut. The one furthest from it is welded to the mount.
2. Repeat the process for the top is the same, except that the nut that holds the stud to the mount is NOT welded on. I was able to access it without removing the mount. You may need a second 12mm wrench to hold the nut stationary while you loosen the top ball mount. Retain the nut and discard the old strut.
3. The new ball mounts are the same thread pitch as the factory parts, but use a 13mm wrench. Install both ball mounts to the car.
4. Hold the strut so that the exposed portion of the strut is facing downwards (as were the factory struts). Start with the bottom first. Simply press the strut onto the ball mount. There is a spring clip that will move out of the way to get around the ball mount, then lock back into place once the ball mount is inside the strut.
Repeat other side and enjoy your hood not hitting you in the head.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
On both of my models, G50 and FGY33, I found it easier to disassemble the upper brackets when mounting the struts.
lpreston
Car: 97 Q45
I've got skinny fingers and a lazy streak....lol. Actually the nuts were not that hard to get at, but I do wrench all the time.
NightRiderQ45
Car: 1998 Infiniti Q45
pic of product...link?
lpreston
Car: 97 Q45
NightRiderQ45
Ok I saw this on ebay yesterday. So do they work pretty good? I was thinking about purchasing them.
lpreston
Car: 97 Q45
Absolutely. The struts are the right length and the replacement ball mounts that you need are included. The seller shipped very quickly as well. I'd recommend him!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Used the Strong Arm on my FGY33 and Stabilus by Sachs on the G50.
Both worked as well as OEM so far. Used their mounting hardware on both.
miata007
Car: 2009 Cube 6sp, 2005 G35 sedan
That's cool that these struts work without costing an arm and a leg.
It's about time for me to change them since I get embarassed everytime I check fluids at the gas stations. I have to go to the trunk to get my wooden stick/pole use to keep the hood up.
007
qship96
Car: 1996 Infiniti Q45
Nah, one day that pole holding up the hood will come in handy as a club to ward off a would be car-jacker!!! Sharpen one end to a fine point and it becomes a multi-purpose weapon and hood prop in one!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Don't forget the way those wilderness traps work!
Hood pole is also a trip device. Not worth damage to fingers and even arms from the heavy hood closing on them.
NightRiderQ45
maxnix wrote:On both of my models, G50 and FGY33, I found it easier to disassemble the upper brackets when mounting the struts.
I had to bump this thread because I'm about to purchase the hood struts. Maxnix are you talking about the bracket that has the two bolts? I know that my finger can't get behind the bracket to take the nut off so it seems like the best option is to take the two bolts off and remove the bracket.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
That's what I did. Take the upper bracket off with the strut, then remove it from the strut while the whole assembly is off the car where you have more room to work.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, much easier for me to remove the bracket on the hood.
Be sure it is securely propped and don't hit the prop! The true meaning of props to you!
NightRiderQ45
Thanks for both replies fellas.
ZMARKUS
Car: 1999 Infiniti Q45T
2002 Infiniti Q45
I
wondered would these be the right length because another seller had wrong length. Gonna buy now since I know they work.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It's would be nice if they would include the Sachs part number to confirm the fit.
NightRiderQ45
Actually this is the link that I was looking for. You are right, the seller ships very fast. I got it in two days but I haven't left any feedback since I haven't installed them in yet. I noticed that the seller did include their ball mounts.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Ball nuts, washers, everything should be included.
NightRiderQ45
Well, washers wasn't included in my package but I got them installed yesterday! I'm glad that i can finally pop open my with no trouble again.
