Factory color temp is around 4300K. The lower the kelvin temp(color temp) the more light output. If google serves me right the lamps you bought are actually halogen lamps with a coating that changes the color, which in turn will make them dimmer. It doesn't matter if your low and high beams match because chances are you'll hardly be using your high beams and they're 2 completely different types of lighting. Does that make sense?bradesp wrote:I just purchased a pair of Halo HID 7500K HB3 Highbeam Bulbs. I want to also replace my low beam bulbs (D2R) as well, but I've noticed that the low beam bulbs seem to be in the 6000k and 8000k temp range... does it matter if the color temps are different between low and high beam bulbs? Also, if I was choosing between 6K and 8K for low beam, would 8K make a better match for my new 7.5K high beam bulbs?
Thanks!
Bradesp
I'd have to disagree slightly there... my google for "Halo HID 7500K HB3 Highbeam Bulbs" turns up with this thread... but otherwise HID links (unless you look at stuff that's older, 90s).Empty V wrote:
Billy
All of my google searching of "Halo HID 7500K HB3" sent me to pages that say HID but in the fine print says Halogen. If you look at the pictures they're all halogen lamps. I don't think Halo makes HID Lamps.UndeGuy wrote:
I had thought that Infinity had used halogen lowbeams, but obviously not.
re: bradespIf you're going for looks, I would think 8000 K is a closer match than 6000 K. Otherwise, not really sure it matters, like Empty V said. I know some vehicles can have high and low on at the same time, can the QX4? In the PF, I can, if I hold the switch in a specific position (and if I was using halogen bulbs).
