IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sat Nov 20, 2004 7:35 pm
no, your not gonna go into the motors internals.
off the top of my head-
basically, you have to remove the intake up to the throttle body.
remove the fuel feed and return lines from the fuel rail.
drain the coolant, and remove the upper and lower coolant hoses. remove the coolant lines from the throttle body, and remove the radiator [for extra room to work].
disconnect the harness connections for the injectors, CAS, TPS, and distributor and any other sensors on the head.
remove the spark plug wires, and spark plugs.
remove the valve cover.
set the motor to TDC compression stroke, and remove the distributor cap. take a note of the position of the rotor. when you reassemble the motor, the distrib MUST be in the exact same position [that is why it is important that the motor is at TDC when you make this note.]
remove the distributor.
unbolt the exhaust manifold from the downpipe [lots of penetrating oil, and curse words...] only remove the exhaust manifold at this point if you have to [for example, if the downpipe bolts do not permit you to use the manifold in helping to get the head off the block]
remove the throttle cable.
remove the timing chain.
unbolt the head. [you must have an FSM for this. the head should be unbolted in a specific sequence, or you can promote warping/cracking]
make sure everything is disconnected/clear of the head and intake and exhaust manifolds.
use the intake and exhaust manifolds to give you leverage in breaking the head free of the block [it will be pretty stuck on].
once the head is off, you can then unbolt the intake and exhaust manifolds, if you want to change their gaskets. its just easier to remove the manifolds when the head is off the block, so you dont have to get to their bolts in akward positions.
the gasket comes off with brake cleaner, gasket remover, fine [220+ grit] sandpaper, and lots of effort. DO NOT GOUGE THE SURFACES!!
the head may need to be resurfaced, depending on the exact cause of the blown head gasket. [example- overheating causes warpage, so the head will need to be machined or replaced]
you most likely need to use a NEW set of head bolts.
installation is the reverse of removal.
NOTE- get a service manual!!!! this is just a rough guide to give you an idea of what to expect. certain items [like head bolts] MUST be installed in a specific pattern, with a specific number [usually 3] of torqueing steps.
