Replacing Haydraulic Tensioner
NICONick
Car: 1993 S13
I believe mine is going bad, my timing chain noise is becoming louder n louder. Its not the guides...
What goes in to replacing the Hydraulic Tensioner?
Thanks for your help!
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
fsm
NICONick
Car: 1993 S13
numbnuts240 wrote:fsm
Factory Service Manual? Don't have one.... There a write up somewhere?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Check on here, Nico has FSMs right here on the boards.
numbnuts240
2011 Ford Focus
2010 Mazda 3
http://www.nicoclub.com/FSM/240sx/1994/
NICONick
Car: 1993 S13
Well the FSM has said u basically have to take off the whole top end, but I believe I've heard some different things from different people. Doesn't anyone know? or Hasn't anyone ever replaced this hydraulic tensioner and can shed some light on this for me?
poshatch
Car: p.o.s. 1990 240sx hatch
am i mistaken or is that the same as the chain tensioner?
if it is then you got to pull off the chain cover to get to it
NICONick
Car: 1993 S13
poshatch wrote:am i mistaken or is that the same as the chain tensioner?
I believe one is hydraulic, maybe someone who knows for sure can shed some light....
poshatch
in either case you still have to pull the chain cover.. i think you got the top guide and the side guide and the tensioner in the middle left area
when that goes down your pretty f*** so yea basically
valve cover off
chain cover off
id try to get the tensioner on/off with the chain on without messing wiht the chain
new sealant and boom
vancouverbc
Car: 1991 240sx
1991-1994-240sx-replacing-timing-chain- ... 55023.html
there is a video somewhere of how to lubricate the tensioner
NICONick
Car: 1993 S13
Ok, so I just got my car back from the shop and they basically couldnt tell me what the prob with my car was. Here's the situation. My oil light randomly comes on and off, along with that my timing chain sounds like it's going to go through the valve cover. This is why I'm thinking timing chain tensioner. Someone please help.
Anybody in the South Jersey area want to take a look and maybe come help me out? Please help NICO !!!
vancouverbc
Car: 1991 240sx
NICONick wrote:Ok, so I just got my car back from the shop and they basically couldnt tell me what the prob with my car was. Here's the situation. My oil light randomly comes on and off, along with that my timing chain sounds like it's going to go through the valve cover. This is why I'm thinking timing chain tensioner. Someone please help.
dont drive the car if you have an oil pressure problem. fix the oil pump or whatever is causing the low pressure. i think the tensioner depends on oil pressure to work. search a bit. but take the front cover off.
JayArr
Car: 1990 Nissan 240SX Coupe
I hate to say it Nick but that engine needs to come out. New oil pump for starters and then look at the timing chain, if the tensioner has failed and the chain has been running loose there could be all kinds of damage up there plus the possibility of shavings and debris.
It sucks, but if you keep driving it you have the distinct possibility of trashing the whole motor if the chain fails or skips, heads. valves, pistons - it could all be toast.
Dattebayo
Oil pumps rarely fail, but the tensioner or other parts can wear out and clog up the oil feeder holes. DO you have a large dent on the oil pan? This can starve the pump and cause all those problems as well...
