Replacing Glove Box Light ... HELP!
filament
Car: Nissan Altima Coupe 2008
Does anyone know how to access the glove box light to replace it?
stsxcrle
You have to take the whole glovebox apart from what I could see, initially I was going to try and replace it with an LED. Pulled the whole glovebox apart and was able to take it out. The only thing is it's a weird bulb, it has two really long (about 3/4") metal pins which then plug into the outlet.
salj838
Car: 2008 Nissan Altima Sedan 2.5S
Hi guys, check google to see that the bulb is similar to T.175 and some sites call it 74. But still the problem is I dont know how to detach the bulb to the black housing the bubs is encased. Blimey.
headhunt3r
Car: Altima Coupe 2.5S w/ CVT
http://www.nicoclub.com/FSM/Altima/2008/inl.pdf
INL-78 <- Look here and trace back.
I suggest spending some time downloading all the PDF's onto your local hard drive so you don't have to wait for them to load every time.
The FSM is like my personal How-To for factory parts removal :)
