replacing fuel injectors
dhen
Car: MGA w/ CA18DET
Hi everyone.
I think I know how to do this but I just want to make sure since I've broken things in the past because I didn't know what I was doing and it's really not fun.
Anyway, I did RTFM and it says to remove the "intake manifold stay." What's that mean?
As far as I can tell, all I need to do to be able to remove the fuel rail is remove these two parts and of course the bolts.
Am I missing anything?
Also, I got a set of 2g DSM 450 injectors. I read the installation guide in the FAQs, anything else I should know?
Thanks,
Darian
float_6969
Intake manifold stays are 2 black peices of metal, that look like tubes with the ends smashed flat and has holes in them. They attach the upper plenum to the lower sub-manifold.
dhen
Car: MGA w/ CA18DET
I really appreciate the help. Are there any parts that can easily get lost when I remove the two pieces I circled? Sorry if this sounds stupid, but I really don't want to create extra problems for myself.
Thanks,
Darian
float_6969
Bolts?
Ca_Silvia
Make sure you have newish rubber seals for all the injectors. When i switched to my 440's i had to replace them. 20 year old rubber sucks, who would have guessed...
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
And lubing up the tops of those injectors with a little dish soap will help them slide into the fuel rail easier. The DSM injectors can be a tight fit. Keyword "can."
dhen
Car: MGA w/ CA18DET
Thanks everyone.
I got the rail off and replaced the injectors. I lubed up the o-rings with engine oil and they slid in. No real drama and it will be much quicker last time.
One issue I did have is that the DSM injectors are a little shorter. I've tightened all the bolts, but I can't get the injectors to go all the way into the fuel rail. So far I haven't noticed any leaks, so I guess it's OK.
Darian
