Replacing Fuel Filler Door Plunger Thing-A-Ma-Jig Doohickie
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
It appears as though I have mortally wounded my electric plunger doowhatzit. My fuel door is now perpetually ajar and it gives me an air of moron as I motor down the road. Anybody ever replaced one? Dealer part or "other"? Looks like it just bolts in, but my vision is heinous these days.
Its a bummer man.
Q451990
First failure I've heard of. Have you tried lubricating it? I know it's controlled by the same solenoid as the trunk release.
Heath
oldmako
Yes. It looks to me the end of the plunger itself done broke. That's modern English for ya. "done broke".
You push the door fully closed and it catches on nothing. It whiffs. Airball. Goose egg. El no grippo. IOS says $180. Junkyard says $20. Hmmmmmmm
qship96
Car: 1996 Infiniti Q45
pfffffft. $2 roll of duct tape,cut off 2" of that s*** every time you fill the tank and tape that mofo closed,end of problem!
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
qship96 wrote:pfffffft. $2 roll of duct tape,cut off 2" of that s*** every time you fill the tank and tape that mofo closed,end of problem!
:chuckle: :chuckle:
Q451990
I think I'd go used on that one - since it's a rare failure item. I'm wondering if it's just stuck in the retracted position though?
Heath
oldmako
Neg. I thought that about my Johnson too.
Skibane
Car: 2000 Q45 AE 110K
Q451990 wrote:I think I'd go used on that one - since it's a rare failure item.
Yep.
You ain't likely to break off two of those, in a couple dozen lifetimes.
Junkyard solenoid + 10 drops of Dexron III inside the plunger = no problems for the next 100 K or so.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Just for kicks, I found the part in the parts book
78850-6P020- ACTUATOR ASSY- FUEL LID OPENER
Brand new is about $100 from Joe but as others said you should be easily able to find a used one.
