DeanM45 »
https://forums.nicoclub.com/deanm45-u203567.html
Sun Mar 15, 2015 7:40 pm
Yep, subframe drops easily, support the motor (I just used a regular hoist), unbolt the motor mounts, unbolt steering knuckle and then unbolt the cradle. Pretty straight forward, I had to do it when I was building my headers. There is also the usual power steering lines (rack is bolted to subframe) , brake lines, sensors and the stock trans cooler lines are bolted on as well. Easy to do once you get under it. Two floor jacks can support the cross member easily and with two people it is really easy to move around.
