artandscience »
https://forums.nicoclub.com/artandscience-u25431.html
Mon Feb 28, 2005 1:20 pm
On the advice of several in this forum, I replaced my upper linksmyself over the weekend. I also took apart the MAF assembly and cleaned it and the interior of my throttle body housing. Also took the time to R&R the fan blade. Lots of fun.
R&R of the link is made _much_ easier by removing the shock first. I just couldn't see an easy way to remove the upper link's securing bolt without removing the shock first.
In the process, I checked my rears too and figured out that I need to replace the RR shock. Is the Tokico in any way inferior or will it work well with an otherwise stock (no T, A) suspension? I have Yokohama AVS Db s2 tires (which, btw, have worn far far better than my Conti Extreme Contacts on the front). 10,000 miles and the Contis are shot.
Next month is new shocks and plugs.
