replacing foglights on 95 Q45
willie
Car: 1995 infiniti q45
I'm trying to replace a set of foglights and brackets on a 95 Q45 and I need to know if I have to remove the bumper to replace the drivers side bracket and light?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
welcome to NICO.. You dont need to remove the bumper to replace the fog lights.
willie
how do I replace the foglights if I don't have to pull off the bumper? I need to replace the brackets on both lights and it seems like the air intake duct work is in the way! So could you give me some insight into replacing them!
goody90q45
Car: 1992 Infiniti Q45 (sold)
The 1" wide plastic piece next to the light comes out first and then you'll see the screws holding in the light assembly and the bracket. It's been a while since I've removed mine but as I recall a gentle pry on the bottom (?) with a screwdriver will pop it off.
Look closely at the screws/bolts before removing them. You don't want to mess with one screw that adjusts the beam angle.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
willie wrote:how do I replace the foglights if I don't have to pull off the bumper?
It can be done, but you will wish you had removed the front bumper cover to replace the foglight brackets. So much easier with it out of the way and the car on a lift.
