Replacing fog light on 2008 M35X
shanebriscoe
Car: 2008 Infiniti M35X
Can anybody please tell me how to replace the fog light assembly on my 2008 M35X? The lens broke from something on the highway. Thanks!
merlinq2
Car: 2007 Infiniti M35x
have look at the down load section the and pour through the service manuals, the details are in there somewhere.
Good luck
http://www.nicoclub.com/FSM/M/2007_M45-M35/
merlinq2
merlinq2 wrote:have look at the down load section the and pour through the service manuals, the details are in there somewhere.
Good luck
Step 1- found in EI – on page 20 Diagrams are on these pages as well
FENDER PROTECTOR PFP:63840
Removal and Installation NIS0024J
REMOVAL
1. Remove rear end screw of fender protector (rear).
2. Remove clips of fender protector (rear).
3. Remove plastic clamp from wheelhouse arches, and then remove fender protector (rear) from wheel
house.
4. Remove screws of front under cover.
5. Remove front end screw of fender protector (front).
6. Remove front end clip of fender protector (front).
7. Remove fender protector (front) from wheel house.
INSTALLATION
Install in the reverse order of removal.
Step 2 found in LT- on page 210 Diagrams are on these pages as well
Bulb Replacement NKS003RI
1. Turn lighting switch OFF.
2. Remove fender protector (front). Refer to EI-20, "FENDER PROTECTOR" .
3. Turn bulb (1) counterclockwise and unlock it.
4. Disconnect connector (2), and remove bulb (1).
CAUTION:
_ Never touch the glass of bulb directly by hand. Keep grease
and other oily matters away from it. Never touch bulb by
hand while it is lit or right after being turned off.
_ Never leave bulb out of fog lamp reflector for a long time
because dust, moisture smoke, etc. may affect the performance
of fog lamp. When replacing bulb, be sure to replace
it with new one.
Removal and Installation NKS003RJ
REMOVAL
1. Remove front bumper grille (1). Refer to EI-13, "Removal and
Installation of Front Bumper Grille" .
2. Remove screws (2) and remove front fog lamp (3) from vehicle.
: N•m (kg-m, in-lb)
INSTALLATION
Installation is the reverse order of removal.
Front fog lamp : 12V - 55W (H11)
shanebriscoe
Thank you so much for the help on replacing my fog light!!!!
Shanebriscoe
merlinq2
How did it work out for you?
