Replacing fan clutch
omarblackg50
Car: 1994 q45
Can someone point me to a how to thread.Thanks
qship96
Car: 1996 Infiniti Q45
Simple....unbolt the 4 bolts holding it to pulley and remove with fan blades still attached- then on bench unbolt fan from clutch and swap with new clutch.....entire process is 10-15 minute job performed from topside EASY
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
qship96 wrote:Simple....unbolt the 4 bolts holding it to pulley and remove with fan blades still attached- then on bench unbolt fan from clutch and swap with new clutch.....entire process is 10-15 minute job performed from topside EASY
Those bolts aren't the easiest to get off/on. Nuts, not bolts, aren't they?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
paranoidjack wrote:Those bolts aren't the easiest to get off/on.
zer...a-tip
paranoidjack wrote:Nuts, not bolts, aren't they?
Yes
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
Paul Wall wrote:
zer...a-tip
Yes
Thanks Paul, but I was referring to their location and not condition. Behind the fan blades and tight spot, if you're using a traditional small 10mm box wrench you'll scratch your hands up. No room for a ratchet, use the longest 10mm you can find. These nuts are never corroded.
qship96
I had no problem doing mine a few years ago during the cold winter using a simple 10mm wrench- take one off, spin the fan 90 degrees with your hand to get the next one, and so on- 10-15 min max with no cuts or scrapes
HERE is my original thread from 2005 when I did the job zerothread?id=102167
Modified by qship96 at 8:59 PM 4/3/2010
Skibane
Car: 2000 Q45 AE 110K
paranoidjack wrote:Thanks Paul, but I was referring to their location and not condition. Behind the fan blades and tight spot, if you're using a traditional small 10mm box wrench you'll scratch your hands up. No room for a ratchet, use the longest 10mm you can find.
A really, REALLY good reason to buy a 10mm flex-handle ratchet wrench...and maybe a 12 and 14, too, if you're feeling spendy...
omarblackg50
Car: 1994 q45
thanks guys was a 10min job after all.
