Replacing factory stereo with aftermarket diagram
new2g35
Car: 03 G35 Coupe+sport+NAV
I am looking for a video or a diagram on how to wire a after market stereo with the Metra 99-7604B with harness and AXXESS ASWC steering stereo controls on a 03 G35.
Thanks
telcoman
Do a search for the FSM and follow the electrical schematic wiring diagram
Good luck
Telcoman
joe603
Car: 2014 Durango R/T
A link to the FSM is in my sig. Good luck!
Gilley
You really don't need a schematic with a wire harness adapter. You connect the adapter's pigtail wires to your new stereo (that's where you need the schematic of wire colors but they generally match the colors on the harness pigtails) then you plug the harness adapter into the stock harness on the car.
Even though the G does not have a power antenna, it does have a powered antenna amp, so be sure to connect the power antenna turn on wire from your new radio.
You're also going to need a Nissan diversity antenna adapter. These cars do not have the conventional antenna plug.
Gilley
You don't need the wire schematic with the axxess steering wheel adapter either. It comes with online instruction that tell you what connector to use and what wires to use to get the steering wheel buttons to work.
