replacing exhaust manifold on rwd ca18det
1mns13
Car: Freedom and cars
Any tips on getting at the nuts? It was a PITA to remove. I was hoping somebody had thought of a way of making the job easier.
Trigger
torch?
1mns13
A torch is no good for getting the nuts back on. I found the closeness to the turbo in some areas made things difficult. I used mostly wrenches and regular sockets. I was wondering if a wobble socket or something else might help. I now have stubby wrenches which should help a bit.
Nismo1182
Car: Z06
The 2 on the bottom right closest to the turbo are a PITA with the water lines in the way. You have to use a open end wrench on those. All the others are a piece of cake with a 3-4" extension and a socket.
nab911
Car: 93 Nissan 240SX SE
Thats why everyone says replace the turbo while the motor is out of the car ;)
Trigger
i still like the torch idea :D
1mns13
It appears everybody has just suffered through it like myself. I had hoped somebody had found some tips by doing the job once or twice before.
biosehnsucht
get gear wrenches....
if you can afford them
1mns13
I have them, and they are worth every penny.
Nismo1182
Car: Z06
Get rid of the coolant lines and it makes it much easier.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
get some cheap wrenches and bend them into some good angles that would help you.
1mns13
The vehicle is sold, so they would prefer to keep the coolant lines. But I understand why people use braided lines for ease. Cheap wrenches are a good idea.
f s t caz
Car: VG30ET D21 Extended Cab Pickup
it was very easy to do w/ the motor out of the car... the only thing better than a set of gear wrenches is 2 sets of gear wrenches: 1 regular set, and 1 stubby set.
1mns13
Grinding the exhaust manifold washer closest to the firewall helped big time. The water lines aren't that bad. All in all I think the same job was easier on my SR, but this CA is in a Silvia, so not having a steering shaft in the helped with the downpipe hookup.
float_6969
Lots of scraped knuckles and lots of time. I need to get some stubby wrenches. It was a pain doing it with out.
slw240sx
Car: 1990 Ca18det 240sx Hatch
line wrenchs work well too.
wow spelling wrench like that looks soo wierd after 23years of spelling it Rench....
float_6969
Hooked on Foniks worked for Jon!
slw240sx
my last name is Rench so its wierd for me lol
float_6969
Ohhhh. Now I feel like a dolt...
