Ezekial »
https://forums.nicoclub.com/ezekial-u22604.html
Sun Sep 25, 2005 7:22 pm
Thanks for the link!
It lists the following parts as being needed!
2x 01121-04711 - bolts for new guides NA4x 11051-60U04 - cam end seals NA2x 13021-60U00 - crank/cam sprockets NA2x 13028-60U00 - timing chains $99.881x 13070-60U03 - chain tensioner(RH) $49.901x 13070-60U12 - chain tensioner(LH) $49.904x 13075-60U02 - tensioner bolts $ 5.201x 13079-60U01 - tensioner gasket(LH) $ .562x 13085-60U01 - chain guide $13.182x 13085-60U11 - chain guide $13.181x 13091-60U01 - guide(tension RH) $49.851x 13091-60U11 - guide(tension LH) $49.852x 13094-60U00 - guide bolts NA1x 13510-60U00 - front cover seal $ 5.341x 15041-60U00 - oil pump chain $33.881x 15043-60U00 - crank/timing sprcket NA 1x 15044-60U00 - crank/oil sprocket $33.881x 15072-60U00 - bracket oil pump NA1x 15073-60U00 - oil pump chain guide $ 4.871x 15073-60U10 - oil pump chain guide $30.852x 13270-60U00 - valve cover gaskets NA8x 14032-60U01 - intk manifold gskts $24.80
Is this for real?
I cant see why i would need any of the ones that arent bolded!?
And perhaps the oil pump chain if its got too much slack
