ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Tue Mar 23, 2004 8:28 am
The car should be off the ground when you remove the TC rods. You shouldn't worry about removing and reinstalling the TC rods, because that is the easy part of the process, only 6 bolts total. The hard part is removing the old bushings, and pressing in the new ones. I cut out my old ones, including the metal collar that almost looks like it's part of the rod, but it's part of the bushing. Mine were so old, I couldn't tell. Anyway, the hard part is pressing the bushings in. Good luck.
