pittpa »
https://forums.nicoclub.com/pittpa-u124931.html
Wed Jun 17, 2009 1:30 pm
I just changed the right one on my 2004, if yours is the same. I pulled on the bumper to pop the fender liner out a bit. I reached in and twisted the light holder up in the housing. It's awkward, take off the wristwatch, roll up the sleeve, it's recessed a bit. You can pull out the whole unit if you remove 2 nuts, but I doubt it is any easier. Pull out the light and reverse procedure. Getting it to turn back in was more awkward. I bought a 50 watt light at Pep Boys to brighten things up a bit. It was meant to replace a backup light and I had to put tape over one of the contacts on the base, otherwise worked like a charm.
