Replacing broken rear emergency brake cable.
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
blk
Car: 2005 Nissan Titan
I removed the broken left emergency brake cable and would like to put the rotor back on the lug bolts without a new cable hooked up yet. When the cable gets here can I just push it in the hole and will it clip itself to the actuator or do I have to dissassemble the actuator and install then replace the rotor?
centralcoaster33
Car: 1997 Nissan 240SX #5
Hi Blk, welcome to NICO Club!
I think you can bolt up your stuff fine and go without an e-brake. When you do get your cable, I suspect you'll have to pull the caliper off of the knuckle to install the cable through the lever. So, yeah, you'll be taking it all apart again.
Return to “Nissan Titan Forum”
