Versa Madness »
https://forums.nicoclub.com/versa-madness-u82770.html
Wed Jun 25, 2008 4:46 pm
The procedure is described starting on page AV-41 of the Versa Service Manual.
Here it is in a nutshell.
1. For hatchback, remove the luggage side upper finisher (LH).2. For sedan, remove the rear pillar finisher.3. Remove rear assist grip (LH).4. Remove three clips of headlining (rear side). Pull down headlining (rear side) and obtain space for work between vehicle and headlining.5. Disconnect the roof antenna harness connectors.6. Remove nut (A) and clips (B).7. Remove the roof antenna.
