Replacing BCM on 2007 Nissan quest
A forum for the Nissan Quest... minivan lovers unite!
merrittr
Car: 2007 Nissan Quest
Hi All I was provided the GW-18 link and I see image 2
just having some problems figuring out how to get to the BCM on my 2007 Nissan quest.
any hints or procedures I can follow?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's a bit of a PITA on older Quests, you need to drop the parking brake pedal. See BCS-25 here....
https://www.nicoclub.com/service-manual ... %2Fbcs.pdf
...and PB-5 here:
https://www.nicoclub.com/service-manual ... 7%2Fpb.pdf
Pauli925
Car: 06 Nissan Quest SE 3.5 V6
Do you need to Program The BCM when replacing them and can one from a junkyard be used?
VStar650CL
Technical Expert
Depends whether you have I-Keys or steel keys. With I-Keys, if a used BCM is installed then you need new fobs. Used fobs will not mate with a different BCM unless the BCM is new. With steel the existing keys can be reused.
The keys need to be re-registered in any case, and a used BCM may need to be configured. Configs on an '06 are with/without for Auto Lights, Fogs, and Speed Sensitive Wipers. Anything misconfigured in the BCM won't work or won't work right.
Pauli925
Thanks I have Chip Keys and the NATS security in my 06 Quest SE and I guess it’s the same as in a Maxima 3.5 v6 L for all this kind of thing and for the ECM as well
VStar650CL
Technical Expert
Pauli925 wrote:
Tue Sep 24, 2024 10:23 pm
That's steel, so you should just need the keys reregistered for it to run. Make sure the part number is an exact match or supersession for what's in the van. BCM's can't be reprogrammed, and in a worst case a lookalike can cause catastrophic electrical damage.
Return to “Quest Forum”
