Crutchfield has not updated their database and does not have any data for the 2008 M's so you'll need to put in 2007...however I cannot say for sure if there are any mounting or space differences between 2007 and 2008maqueswell wrote:If you go to http://www.crutchfield.com and put in the model of Infiniti you own it'll automatically tell you whether or not the speakers will fit in the car.
Did you have to remove the door panels to do this?NightWatch wrote:I replaced the stock speakers with Alpine SPR-13C's in all 4 doors. The difference was amazing and I was happy with it for a while but I still needed a more solid defined bass note. So I installed an Audio Control Epicenter Plus and an Infinity BassLink powered subwoofer. My goal was not to modify any of the controls or disturb the factory look. I'm very happy with it now. Although if you're looking for bass that arrives at your neighbors house 5 minutes before you do, then you may need a different setup. This one is designed more for tone and clarity than for loudness.
I am curious as to what you think of the basslink as I have one that Im about to install. Also where did you put the volume control for the basslink as well, thxNightWatch wrote:I replaced the stock speakers with Alpine SPR-13C's in all 4 doors. The difference was amazing and I was happy with it for a while but I still needed a more solid defined bass note. So I installed an Audio Control Epicenter Plus and an Infinity BassLink powered subwoofer. My goal was not to modify any of the controls or disturb the factory look. I'm very happy with it now. Although if you're looking for bass that arrives at your neighbors house 5 minutes before you do, then you may need a different setup. This one is designed more for tone and clarity than for loudness.
I would not think that there would be any differences from 2006 onward; right? I would think the fittings virtually identical. Installation requires drilling new holes and some splicing in most 6.5's I saw.NightWatch wrote:
Actually the base model (at least in 2008) has 6 speakers, don't forget the two dome tweeters in the upper dash corners of the front doors. Deciding what to do with these actually occupied most of the time in swapping the door speakers out. Originially I left the original wiring in place and kept the independant tweeters in the front along with the 2-way speakers in the doors. Then out of curiosity I disconnected the tweeters in the top of the doors and bypassed the "crossover" and wired directly to the speaker. I didn't really notice any difference in sound, so I put it back. Best to do your experimenting with the door pannels off as putting them on and taking them off repeatedly eventually ends up in broken door pannel clips.Allosaur wrote:
Crutchfield asked me if I have 4, 6 or 8 speakers. I would think that the base model would have 4, the journey version 6, and the premium/tech versions the full Bose 8 speaker system. (I am new to this car. Just guessing. How close am I?)
What happened to the E500?Allosaur wrote:How about the base model for 2006; 4 or 6 speakers? Is this a Bose system entirely? With my previous MB E500 I had the Bose and one could not add an amp or anything given the fiber optic wiring setup. I am hoping otherwise with this application.
Indeed, there is no substitute for experimenting and you have done the work in this regard and to you the rewards and a benefit to the rest of us for adhering to your advice.
Regarding Crutchfield, I was just using this as a fitting example and what might be expected in said installation. Actually, I am not a do-it-yourself guy when it comes to audio and would never order components to be installed myself (from anywhere). Living in Fort Lauderdale, there are myriads of places heavily competing and slashing prices right now that have expert installers. I would simply go to one of them after pricing things out.
Personally, though, if redrilling some new holes enabled the larger (and better?) speakers, I would opt for the larger speakers (6.5 or even 6.75) unless there was some real harm being done, and in this case it would not appear to be the case. Just a choice.
Thanks for your input.
You mean where is the car now? Its been traded in. On the speaker setup? No, I never made any alterations because this was highly discouraged by everyone and anywhere I went. So I left it stock.M35 Sport wrote:What happened to the E500?
Yeah I mean you went from a V8 to a V6 Seems like you would have kept the benz. Was it leased? What it full of problems? Just wondering.Allosaur wrote:
