replacing backseats with stereo equipment...
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
O.K. so my project is starting within the next couple of months (that's when it's getting brought here from Ohio by my family...) It's an S13.. One of the things I'm wanting to do is replace the backseat with stereo equipment (subs, mids, amp and highs of course.) I'm wondering if anyone has ever seen this done? I've seen plenty of 2 seaters with the section behind the seats turned into a full arsenal of stereo equipment.. But never done to a car that originally had a backseat... Does anyone have any ideas on how to make this work? I'm thinking make a decently large box to mount everything that the bottom is fitted to the floor board? I'm pretty set on this idea, so if you're someone that's just going to knock it because you particularly don't like it, please just avoid replying... (Your insults won't change my mind) Thanks in advance to anyone who has some decent ideas...
KoopaTroopa
Car: 1991 black hatch
What my one friend did was completely strip the rear seats and everything under them, then fiber glassed on top of where the seats were. He pulled up the fiber glassed mold and then made a box with that as the base. Its pretty heavy but once you slide it into the sweet spot it fits better than a lego. It definitely isn't going anywhere but just incase of an accident he did attach straps to the back and anchored them in the trunk.
s13importuner7
Car: 1991 240sx
KoopaTroopa wrote:What my one friend did was completely strip the rear seats and everything under them, then fiber glassed on top of where the seats were. He pulled up the fiber glassed mold and then made a box with that as the base. Its pretty heavy but once you slide it into the sweet spot it fits better than a lego. It definitely isn't going anywhere but just incase of an accident he did attach straps to the back and anchored them in the trunk.
thats excactly what i want to do. except also put some like 6.5 inch speakers attached to the box. that be a sweet setup. then maybe in the flat area of the trunk make a flat fiberglass piece with slots to hold your amps and then lay glass over the entire flat piece.
mentordrift
Car: 1995 Nissan 240sx SE
cool idea, it would be interesting if you could find some inexpensive shallow mount subs or something to use - maybe that way you could avoid have a HUGE box behind the seat. I think pioneer has something like that, but I'm just waking up and still groggy...
btw, welcome to ohio, which part are you going to be storing your 240 ?
PyR0NiAk
mentordrift wrote:cool idea, it would be interesting if you could find some inexpensive shallow mount subs or something to use - maybe that way you could avoid have a HUGE box behind the seat. I think pioneer has something like that, but I'm just waking up and still groggy...
you misunderstood the ohio part... i'm originally from portsmouth, ohio born and raised but i'm in the marine corps and now stationed in cherry point, nc... the car is still in ohio at the moment...
btw if anyone could get a pic of this stuff done it'd be appreciated... it's exactly what i'm wanting to do
PyR0NiAk
the idea of doing this is because i find a trunk more useful than a backseat.. don't wanna use up the trunk space
you also missed the point that I said LOWS, MIDS, AND HIGHS... meaning everything is right there.... (I could care less about the sound surrounding me... my music is always too loud for it to matter anyway)
Modified by PyR0NiAk at 11:56 AM 4/4/2009
hilux30
Car: 2007 Tacoma 4x4
I had the local stereo shop build a lightwight box that is flush with trunk floor level, put two 15" and a Amp in the middle, and a trunk cover board, all covered in the same material and matching the car's interior color, looks very very clean and sharp, and sounds kick a**, I'll Email you couple of pics
PyR0NiAk
hilux30 wrote:I had the local stereo shop build a lightwight box that is flush with trunk floor level, put two 15" and a Amp in the middle, and a trunk cover board, all covered in the same material and matching the car's interior color, looks very very clean and sharp, and sounds kick a**, I'll Email you couple of pics
awesome... [email protected] if you didn't already get it from my profile
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
I have contemplated this for years.I always decide in the end to leave the stuff in the trunk, mainly for the fact that even though things can be put back like they were before the job was done, with useful thinking and some mockup, the trunk will have plenty of room once everything is laid out right.One or two 10's is more than enough to sound good in a 240.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
ive always wanted to do something similar. post up pics to this thread when you do it. i think the cleanest stereo mod is installing 6x9s next to the rear seats, or putting them into the privacy cover (which i will be doing) and possible mounting an amp between them. i think clean is better, so whatever you decide, def dont make it busy looking.
hilux30
sent...... don't ask me how much I paid, we traded jobs so the was no $$ exchanged
PyR0NiAk
slyedog240sx wrote:I have contemplated this for years.I always decide in the end to leave the stuff in the trunk, mainly for the fact that even though things can be put back like they were before the job was done, with useful thinking and some mockup, the trunk will have plenty of room once everything is laid out right.One or two 10's is more than enough to sound good in a 240.
I'm the type to keep cars until they are beyond repair, so if I do something, it's very unlikely that I'll ever want to change it back... especially in my s13 considering it's a rebuilt salvage with odometer discrepancy all marked on the title...
hilux30 wrote:sent...... don't ask me how much I paid, we traded jobs so the was no $$ exchanged
did you send it to [email protected] or [email protected] NOTE: the correct address has a zero...
hilux30
why don't post those pics 'cause I still have not found that stupid web-site to host my pics, so go right ahead and show the rest...
PyR0NiAk
http://www.photobucket.com although I used my angelfire account to host my m4 pic because I don't like when photobucket says "f*** YOU NOT ENOUGH BANDWIDTH FOR YOUR PICTURE TODAY" also, I didn't receive your pics.. check my previous post for email issues..
PyR0NiAk
hilux30 wrote:why don't post those pics 'cause I still have not found that stupid web-site to host my pics, so go right ahead and show the rest...
i like how it looks clean and like it's almost suppose to be there, but I am going for a somewhat more flashy interior... not to the point that it's hard on the eyes or looks cluttered most likely some fiberglass work with some glossy paint... either way... very nice work
slysilvias13
Car: 1991 nissan 240sx se super hicas
i wanna make a fiberglass enclosure for the rear seats in my 91 hatch i was thinkin two twelves an two amps at the bottom with some lights!
PyR0NiAk
slysilvias13 wrote:i wanna make a fiberglass enclosure for the rear seats in my 91 hatch i was thinkin two twelves an two amps at the bottom with some lights!
lights are ok if you do them right... some will hate on you for it and call it ricey.. but honestly they're almost back to the point of being original again.. the whole fad of everyone slapping them on their hondas kind of died... just dont make it to where when they're on and you look in your mirror it looks like a f***ing light show in your mirror or as if you're getting pulled over...
hilux30
I'm not in to "show" I like the way it is. I didn't even want this, but I towed a car for the stereo shop and this is how they repaid me. Nice, but if they did fiberglass and light and s*** I would of asked them to change it....
sebazztard
i LOVE it. im going to copy this setup, but i think im going with the 6x9's in the quarters. it doesnt take away from the space in the trunk and utilizes the nonsense that the back seat takes up. perfect.
sebazztard
oh and since were on topic, where would one find a nice carpet to wrap the box with online? the local fabric stores here doesnt carry anything like that so i usually wrap my projects in the best looking material i can find but with a clean look i want to do something similiar to the carpet in the car. any links?
PyR0NiAk
sebazztard wrote:oh and since were on topic, where would one find a nice carpet to wrap the box with online? the local fabric stores here doesnt carry anything like that so i usually wrap my projects in the best looking material i can find but with a clean look i want to do something similiar to the carpet in the car. any links?
this is sad, but i seriously saw some gray carpet at wal-mart in the auto section that looks JUST like the gray that's in the s13s...
sebazztard
ive seen the same kind, but im talking about yards of it. that carpet isnt really long enough to work with when wrapping. they have black and grey i believe.
PyR0NiAk
sebazztard wrote:ive seen the same kind, but im talking about yards of it. that carpet isnt really long enough to work with when wrapping. they have black and grey i believe.
looked like the roll was plenty big enough to me to cover a box or even where the backseat use to be... you could also, most likely, go to some interior shop or even a nissan dealer...
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
im not that into stereos, but id be afraid of someone stealin my crap if they can see it.
just my .02
PyR0NiAk
hbpignosePA wrote:im not that into stereos, but id be afraid of someone stealin my crap if they can see it.
just my .02
friend of mine use to have a j body with 6 12s stuffed where his backseat was... never got broken into... he hada motion sensor style alarm installed.. park it with windows down and ppl cant even reach through your windows without it going off... was so loud it was ear piercing... it definitely seemed to work out for him
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Look for automotive textile stores. They will also have vinyl dye, adhesives, leather, vinyl, etc. Anything you would need for an interior.
slyedog240sx
Menards sells carpet that works well for sub boxes.They will cut it off a big roll however long you want it.I have built quite a few boxes with it.
Broadfield
Car: 1992 240sx
I did this in the back seat of a customers Civic. No my style, but it's what he wanted. I still added my own touch so that it at least flowed with the original lines of the interior. I also did this with no fiberglass.... all wood baby.
Sorry for the crappy pics.... it was back in the day,
audtatious
Sweet
keith0486
wow you dont some of the best work i have ever seen broadfield.
no wonder why your car is sick you must make bank off people wanting custom systems like that that's some good money to do that.
