Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Jul 14, 2008 3:55 am
Since the valve itself is damaged, you'd have to remove the head off the motor to pull the valve out and replace it. If you have to ask how hard it is to replace the valve, you should probably have a shop change the valve out for you. They will make sure the seat isn't damaged/replace it if it is and make sure you have a solid valve to seat seal.
$900 is a lot to pay for that old of a car that needs to have that much work done to it. Also, valves don't tend to bend willy nilly. Something caused it to happen, typically striking the piston during a mis-timed event (ie chain break). I would avoid the car if you're not mechanically inclined, or if you are talk him down as the car could turn into a money pit pretty quickly.
Also, moving to 240 tech
