kidakat »
https://forums.nicoclub.com/kidakat-u17281.html
Wed Jun 16, 2004 2:35 am
Hi again,Thanks for the response. You clearly know much more about this than the local Nissan dealership. I found a used ECM out of an identical low miles wreck off eBay for $25 so I snagged it. When the unit arrived, I installed it and all symptoms are the same.
Here's what's happening:1. When I start the car, the O/D light flashes several times2. The Check Engine light is on3. When driving, the engine doesn't seem to down shift when I step on the accelerator (for example: when passing)
When I first brought the car in to the Nissan dealership for the "Check Engine Light," they scanned it with their system and said it returned a diag code of 1705 and that the problem was a bad "Throttle Position Sensor." After they replaced that, the Idiot light came back on and the O/D light stopped flashing when I started the car. I brought it back to them and they said, "Oh, there must have been two codes in there, it looks like you need a new ECM" I of course, almost fell over when they quoted me a price on having that done. So I decided to try to take a stab at it myself. I'm not 100% sure of what the used ECM is telling me, but it seems like it's doing essentially the same thing that the other one was doing, except for the O/D light is now flashing sometimes again when I start the car (not every time). My gut feeling is that there was nothing wrong with the ECM. Do I need to have this one re-programmed? I had the boys down at AutoZone re-scan it with thier cheapo diag tool and it returned code 1705 even after replacing with the used ECM.
You suggested the TCM or TPS as the possible problem, from what I've been reading in other posts, the TCM seems like a good candidate. Can you tell me where TCM and TPS are located in a '99 Altima. Are there any other model cars that I could pull from in order to get a used one?
thanks so much for your help,
kidakat
