Postby
phmichel »
https://forums.nicoclub.com/phmichel-u237795.htmlSat Oct 15, 2022 8:57 am
R&R alternator on a 2013 Rogue Gen 1. Anyone know if you can access the tensioner from the top to loosen the belt and insert a lock pin? Or do you have to take the wheel off and pull back the inner fender liner?
You're not replacing the belt?? You're gonna regret that one cause it's a BEAST.
Belt was done 3k miles ago. Then (of course) an alternator bearing goes out. Actually the belt wasn't that bad. I'd just rather not jack it up and mess with the fender liner again.
But you’re basically gna have to to change the alternator.
