Replacing alternator in a 95 240sx SE...80 or 90 amp?
goldlifter
Car: 96 Dodge Viper GTS,95 Nissan 240sx,00 BMW 323ci
Are both the 80 and 90 amp alternators interchangeable? Do all SE's come with the 90? just need to know asap before i order one, thanks
Ernest2700
Car: 91 Nissan 249sx se
I have a 91 240sx and i just replaced the alternator with a 90 amp the car is running perfect.
BoBa524
Car: 1995 Nissan 240SX SE
90amp is for SEs with foglights. it wont harm you if you put it into a non-foglight car. it will be better anyways with all the aftermarket electronics that a car powers these days.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Be baller and throw a Nissan Quest Alternator. There's a write-up here on NICO. The Quest Alty is 110amp.
sunnys14
Car: S14
That's what I run, just gotta drill the bottom mount holes a little larger.
stutterr
Car: 1990 240sx
I just got mine rebuilt to handle a ton if amperage. No messing with the mounting points, or a different belt.
You can get it rebuilt, its not that hard.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
I had my alternator rebuilt for a 100 amps at a local shop here in town. Not expensive at all.
