compression »
https://forums.nicoclub.com/compression-u9345.html
Mon May 31, 2004 4:13 am
"fenderwell or from outside the engine bay will net the most gains as it's sucking in colder air"
True, unless you are past the optimum tune length. And, not all cars are hot as hell under the hood all the time. When I designed an itake for the 350Z, we did extensive thermocouple testing. We ran 8 probes to a data logger that were placed all over the car and engine bay. We found that sitting at idle for an extended period of time (3+ minutes) underhood temps did climb to 20+ degrees above ambient. But the second the car moves, they drop. By the time you are cruising at 25 mph, the air temp under the hood was just about equal to the ambient temp.When you really need the air, you are usually on the gas, which means that you are moving at a good speed, which menas there is a lot of air passing quickly through the engine bay from various sources, hood seam, thru radiator, around headlights, etc.
Oh yeah, and the hydrolock thing? I have seen it happen, but if you are not an idiot and dont try to drive through 14" puddles, then you are fine. Regular rainfall will not hydrlock anything.Hope that was usefull.-aaron
