ctrucks »
https://forums.nicoclub.com/ctrucks-u165578.html
Wed Aug 04, 2010 7:16 am
Before you remove the U-bolts, clamp the leave springs together with a G-clamp. One on the left and one on the right. Un-fasten the the U-bolts. Loosten the G-clamps simultaneously before taking out the centering pin. Take out the broken spring and insert the new one. Carefully tighten the G-clamp and make certain the centering pin's hole is lined up. Insert the centering pin, fasten it and then put the U-bolts back. Voila, a DIY leaf spring replacement.
