silpena »
https://forums.nicoclub.com/silpena-u34788.html
Fri Apr 04, 2008 8:54 am
you won't need a new compressor as long as u can evacuate 98% percent of the freon and mineral oil. If ur compressor is bad the oil will be a blackish color with a silvery shine then buy a new one and install a filter to catch any metal shards. You'll just ruin the new one with it. Id say go and look for a used compressor that works well. Have a shop evacuate the freon and mineral oil and remove the compressor ur self. Also i recommend before u take the old compressor off i would use a florescent dye to look for any leaks. All u may need is a new o ring or hose at the connections, but re charging it is gonna cost ya bug bucks so retrofit would be cheaper. No more than 200$ i could do it for less since i have all the equipment to remove, identify, recharge the ac system. Maybe u should try a local community college i bet they would do it for half the price or more. You just gotta trust the students on the job but don't worry the teacher should be watching them or at least i hope... go to napa and ask for a r134-a retrofit kit for a nissan 240sx and get pax oil for the ac. It should say inside ur engine compartment on the hood on how many pounds of freon and oil to use so u don't over charge it. That is just as bad as under charging and it's probley even worse.
p.s. working on the ac system is illegal with out being certified u must certified. just a heads up if ur gonna do it in front of ur house. Also wear some google and good covering clothing. this stuff can freeze ur eyes and make u blind withing a second.
