jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Tue Nov 24, 2009 6:10 pm
well its relatively straight forward. remove rear suspension piece by piece, remove diff, drop the four bolts and wiggle the subframe loose. make sure to have enough support when that thing falls down.
i don't seem to understand how your friend would have improperly installed the subframe. these subframes are relatively easy to bend though. im just assuming installing the diff may have just finished off a problem that had already pre-existed.
