Chris28 wrote:Plan on a weekend. Anything that can go wrong, will go wrong.
^Murphy's Law
but yeah think about this...
nut/bolt/screw wont budge or brokeaccidentals like bending hardlineshose replacementssomething happens to lifting the motornot enough man power to manipulate the entry of working engine
whether your doing this with people or alone, removal of all connections and mountings can be soloed
when you get to that point its either you try to pull it out all as one (better with more people to push down on transmission and stuff like that)or disconnect from the transmission and drop it and pick out the motor
when i swapped from KAe to CAdet it took a day to swap and another day to reconnect everything so i dont think it should take more than a weekend for KADE to KADE
