Haven't done that, but it's worth a try if you recommend it. Also when I opened up the radiator cap the day after driving it had a lot of built up pressure and popped and also had a smell of fuel.Q45tech wrote:Have you replaced/tested the thermstatic controlled fan and made sure the condenser fans operate per FSM?
Stupid question....but....have you verified there is ENOUGH coolant in the engine?vegasdc702 wrote:The engine looks super clean for it having the amount of miles that it has. I wasn't told exactly what happened by the PO other than it overheats after driving for about 30 minutes or so. It continues to do that now, is there something I should be looking at before I pull this motor?
I already have the new engine sitting in the garage waiting to be preped.
